Unable to remove bathtub drain plug
Old 09-12-01, 04:42 AM
Guest
Angry
Have a bathtub drain plug that I'm unable to remove. I believe it's a Delta. It appears to screw in both directions. Is there a trick to removing it?
Old 09-12-01, 06:07 AM
Mike Swearingen's Avatar
Cool
If it's a pop-up drain, you may have to remove the two bolts in the overflow plate and pull out that part of the assembly before you can remove it.
OR, it may be held on with a set screw under the top of the drain itself.
Good luck!
Old 09-12-01, 07:17 AM
Guest
Thanks OldGuy
Thanks Old Guy! Found the set screw.
