Plumbing
Old 12-04-01, 12:06 PM
Plumbing
TAKES 2-3 TIMES TO FLUSH TOILET, HELP. NOT EVERYTHING IS GOING DOWN ON FIRST FLUSH.
Old 12-04-01, 12:44 PM
Plumber2000's Avatar
[SIZE=3]Clean out the flush ring below the bowl ring and the blow hole in the bottom of the bowl, you may also need to install a new fillvalve.[/SIZE]
Old 12-04-01, 08:11 PM
plumbguy
the power and duration of the toilets flush depends on the water level in the tank and how long the flapper stays up. the toilet should deliver a full flush before the flapper drops. you may need to remove the water saving flapper and install a standard one.
then adjust accordingly.
HTML code is On
