shower & tub faucet run at same time
Old 01-16-02, 08:17 PM
Guest
Question shower & tub faucet run at same time
Repiped home using pex with Vanguard manifold. Installed Moen single handle Shower/Bathtub combination fixture. When water is flowing out of bathtub faucet with faucet knob midway between hot/cold, some water also comes out of the shower head. Moen sent me a cartridge repair kit but this did not solve the problem.
Any suggestions?
Old 01-17-02, 06:08 PM
Plumber2000's Avatar
Too much pressure, maybe, high rate of flow, water needs to go somewhere. You can install in shower shut off before the shower head.
Old 01-17-02, 08:28 PM
Guest
I'm going to pull the faucet to see if I have a problem with the diverter. If that doesn't work then I will install a shutoff valve in the shower head supply line and/or tweak the hot/cold manabloc valves. Is there any benefit to upsizing the line running from the valve to the bathtub faucet and shower head from 1/2" to 3/4" diameter pex? Should I check the distance between fixtures?
Old 01-17-02, 08:43 PM
Size will make no differance, distance will have no effect.
Is the diverter not on the spout it's self?
Old 01-18-02, 08:54 AM
Guest
The diverter is part of the spout.
Thanks again for your advice.
Old 01-18-02, 09:40 AM
To much flow, you best option is to install a shut off at the shower head. Then when you want to use the shower open the shut off and lift the diverter on the spout.
