ABS and PVC connection
Old 01-21-02, 06:44 AM
RAMinKC
I am using black ABS for my dwv system and need to attatch a tailpiece to a PVC shower drain. Is there any problems with this? Can I use standard abs cement or do I need to use an all purpose cement which works for both PVC and ABS?
Old 01-21-02, 07:15 AM
A
Use the All Purpose Cement
Old 01-22-02, 08:48 PM
Plumber2000's Avatar
Check with your local plumbing code, most areas will not allow all purpose cement, where I live there is a transition glue that we can use, but only on one joint and only on the outside of the foundation. Use a rubber fernco to make this transition.
HTML code is On
