Anti-siphon Valve for Bidet addon toilet
I have a 99 cadillac seville that stalls while driving down the road. It only lasts a few seconds. Its like the key is turned off and back on or the gas stops then starts again. It has 37000 miles on it. Any ideas.
I recently read from Mr Bidet.com that products from a certain company that have the bidet nozzle that moves into "the line of fire" on a toilet are illegal because they don't have anti-siphon valves.
I have such a device. It works great. Warm clean water.
But be be legal (in case the city shuts off the water and drains the water, there is a risk of contaminated water goes back into the nozzle and to the source. (muni water)
So I need a 1/4" fitted Anti Siphon Valve (ASVF), pref with no power. Any ideas?
Received 1 Upvote
1 Post
There are anti-siphon (aka check valves) that come in all sizes for different sizes of water lines.
Just get one and install it in the line. It allows water to flow only one way, and has a spring-loaded valve that seals the line when water tries to flow back the wrong way.
Good Luck!
Mike
Good Luck!
Mike
