toilet flange
Old 01-24-02, 11:04 AM
Angry toilet flange
I had to put in a new toilet. But when I took off the old one I saw I had to also repair the toilet flange. I have an older home so I think it has been their awhile. I can not get the screws out of the old flange!!!! I don't know what to do? I don't want to mess with them too much in fear off strepping the screws. If anybody knows how to fix this problem so I don't have to hire a plumber. It would really help!!!!!
Old 01-24-02, 11:15 AM
Go to your local building supply store (lowe's, HD) and ask in the plumbing department for a flange repair plate (I think that's what its called).
Old 01-24-02, 12:14 PM
Plumber2000's Avatar
Are you talking about the bolts that hold the toilet to the floor? Do these bolts appear to screw into the flange? Are these what your talking about?
Old 01-24-02, 12:25 PM
flange
Im talking about the screws that hold in the flange to the wood floor. I can't get them out. Any ideas?
Old 01-24-02, 12:45 PM
Phillips head or straight sloted, they should unscrew from there. What type of flange is the old one, plastic or metal?
Old 01-24-02, 12:59 PM
flange
The old flange has straight screws in it and it is metal.
Old 01-24-02, 01:02 PM
Are you wanting to replace this flange, is this why your trying to remove the screws?
Old 01-24-02, 01:24 PM
flange
I have to replace the old flange because it is broken and the bolts that hold the toilet to the flange were rusty and one bolt was missing.
Old 01-24-02, 01:27 PM
Replacing the flange, you will need to cut the old one out, do this from under the house, I might recommend calling a plumber to help out on this.
HTML code is On
