washer drain hose hook-up
My washer drain hose hooks over the side of and empties into my utility sink. I want it to drain directly into a standpipe that "y's" off the sink's 2" waste line. I know the standpipe must be a minimum height of 24" from the floor but I'm attaching the pipe to the sink waste line. Does it need to be longer? Do I attach "Y" where pipe comes from wall, before sink trap? And do I need a separate trap for the standpipe?
Received 1 Upvote
1 Post
I'm not a pro plumber by any means, but I would just 90 over, as necessary, from the bottom of the shortened standpipe to a street-T in the sink tailpiece above the trap.
Allow 1/4" of slope per linear foot of the drain pipe from the bottom of the standpipe to the s-T in the tailpiece.
Maybe one of the pros in here will have a better suggestion, but I don't see why that wouldn't work.
You might get a little backup in the sink when the washer pump is discharging, but it will drain right out down the trap when it quits, so no problem.
Good luck!
Mike
Good luck!
Mike
