Plumbing
Old 02-14-02, 04:18 PM
Katrinka
Plumbing
I was putting down vinyl in my bathroom and used wood as a sub flooring and hit a pipe which started a leak on the first floor of my townhouse. I live in a condominium complex. What can I do to immediately stop the leaking?
Old 02-14-02, 04:21 PM
First if it is a water pipe turn the water off at the main or closest valve. Then depending on what type of pipe depends on the repair. Copper for example can be cut out and a coupling put in the cut place. Plastic sewer pipe can be repaired with a Fernco coupler
Good Luck
HTML code is On
