pedistal sink located away from riser
I'm installing a pedistal sink where an existing vanity was located, i moved my supply lines so they are now located behind the pedistal (hidden from straight on view) and now may have a problem with my existing riser and would prefer not to relocate this. Question - do you think I may have a problem if the drain on the new sink is not in line with the riser? i need to locate the sink about 1-1/2 inches away from the riser pipe.
