Shower Drain?
Old 03-15-02, 02:37 PM
BobG
Shower Drain?
I am installing a shower unit in my basement bathroom and not sure how to install the drain for the shower base. The floor is cement and the waste hole is flush with the floor. The hole is about 3 1/2 inches wide. When I put the shower base in position there is about a 1/2 inch between the floor and the shower base drain opening. Please advise. Thanks
Old 03-16-02, 06:40 PM
tedn332
If you have a pvc drain line in the floor you can come up with pvc and use a compression type shower drain. It will be a brass drain with a rubber collar that fits around the pipe (2"). There will be a brass nut that screws in and compresses the rubber around the pipe to make a seal.
