rusty toilet bolts and nuts tank to bowl
Old 06-08-02, 01:47 AM
dieseld3
Having a problem removing the old rusty bolts from the tank to bowl area. Have the screwdriver and adjustable wrench, and W-D-40. Nothing has happened. Very frustrated. Any other tools I can use?
Old 06-08-02, 07:12 AM
the_tow_guy's Avatar
Received 65 Votes on 54 Posts
Dremel tool with a metal cut-off wheel maybe?
Old 06-08-02, 08:23 AM
notuboo's Avatar
Sawzall or hacksaw.
Old 06-08-02, 11:50 AM
mazie6
Sometimes LiquidWrench works when WD40 does not. Different substances that work in different ways, I was told.
Also adjustable wrenches don't always give you a really good grip. A wrench exactly the right size is better, if you have one, or my tool of choice -- channel lock pliers!
Hope you succeed!
Old 06-08-02, 11:59 AM
worm_killer
i second the sawzall /hack saw method!
worm_killer
Old 06-08-02, 12:04 PM
Mike Swearingen's Avatar
Cool
I always just saw them off. Faster. Easier. Simpler. (My kind of job.) LOL
Mike
Old 06-08-02, 11:07 PM
W
Received 12 Votes on 10 Posts
Hello, Everbody has thier way to remove tank bolts. I to used a hacksaw when I was a kid. Now that I'm older I don't like to mar the porclin so I remove the water from the tank and drill the heads off the bolts. Start with a 1/8 bit and work your way up.This also works on kitchen faucets that have rusted nuts on them. If the bolt spins put a set of vice grips on the bottom.
Good Luck Woodbutcher
Old 06-09-02, 02:25 AM
dieseld3
Thank you to all that replied. Your comments are deeply appreciated.
