Kitchen Faucet
Old 06-17-02, 06:03 AM
rmammes
Post Kitchen Faucet
When I lift up my one handle kitchen faucet, there is a slight hesitation, then the water flows. I did notice that there is a pin hole in my sprayer. Could this be causing the problem, or is it the faucet. I did tape up the hole in the sprayer and problem improved a bit, however, there is still a hesitation. Any suggestions? Should I replace sprayer, faucet..or both???
Richard Mammes
Old 06-17-02, 06:45 AM
Mike Swearingen's Avatar
Cool
If it is a Delta ball-type kitchen faucet, you can get a repair kit to repalce the internal parts.
Good Luck!
Mike
Old 06-17-02, 05:58 PM
Trying2Help's Avatar
Received 7 Votes on 4 Posts
Replace the sprayer. If there is a hole in the line or the nozzle it is allowing the water to leak out when the faucet is off. I would think you would find a wet area under you sink some where? Anyhow, once you turn the wter back on, it has to fill this hose up again before you get water out of the faucet. This problem can cause your faucet to "chatter" too, not always, but sometimes.
