outdoor plumbing
Old 06-17-02, 06:03 AM
pbereg
Question outdoor plumbing
I need to extend my house oudoor water faucet from house ( difficult access) to 'waterstation'. distance about 8 feet.
I cannot dig beacuse of gas line. What kind of plumbing i have to use? How to avoid leak from temperature drop due day and night?
Old 06-17-02, 06:43 AM
Mike Swearingen's Avatar
Cool
You can use copper or PVC for a cold water outdoor faucet supply line.
It should be buried below the local frostline to prevent freezing.
You can safely dig around a gas line with a shovel, and run the line under it, if necessary.
Good Luck!
Mike
Old 06-17-02, 07:00 AM
pbereg
Thumbs up thanks a lot
thanks a lot!
If i intend to use this line only for sprinkling due summer and spring time (Charlotte, NC) do i still have to put this line ( PVC)under ground?
Old 06-17-02, 09:11 AM
Cool
You don't have to bury the line IF you cut-off the water supply to it and drain it to prevent it from freezing and busrting in the winter.
An alternative is to attach a water hose to your existing faucet, and put a quarter-turn ball cut-off on the end of it. The hose will remain pressurized with water.
Good Luck!
Mike
HTML code is On
