Moen help needed.
My single lever Moen shower/bathtub handle has been leaking . I just turned off the main water supply ,took the handle off and pulled out the plastic parts out. Now I am stuck! All I see if a small plastic part inside the brass piece slot.And a small brass clip sticking down into the pipe. How do I get the cartridge out???? Thanks and please hurry before my wife kills me.
Remove the clip and pull the cartridge out.
You can do a search in here on Moen cartridges that may help you.
Good luck!
Mike
Good luck!
Mike
