Vent pitch
Old 07-16-02, 09:31 PM
Vent pitch
OK- This may seem like a silly question. What way should the vent pipe pitch to? Up to the vent stack, or down. It makes sense to me that if there is moisture or condensate, it should go DOWN, toward the main stack. If you think about vapors or oders, it makes sense to have the pitch UP, so, which is it UP or Down, and what is the correct pitch - I think i was told 1/4" every 4 ft - is that correct ?
Thanks for the help.
Old 07-16-02, 11:09 PM
the vent slopes from the stack to the drain. Condensation then drains down into the drainage system and sewer gases, which are lighter than air, vents out the system.
HTML code is On
