low hot water pressure
Received 1 Upvote
1 Post
The water pressure out of your water heater is directly related to the cold water pressure going into it.
If you have a cold water shut-off valve on the heater supply line, make sure that it is wide open.
(Another problem may be if you have galvanized pipes.)
Good Luck!
Mike
Good Luck!
Mike
