tabletop fountain
Old 07-26-06, 09:04 AM
tabletop fountain
I am attempting to create a tabletop fountain for my house. I already acquired an 80gph pump with flow control. My question is, what materials could i use to create the central piece from which the water comes out? I read a few books on the subject but they didnt help. Also, where can i buy those materials? thank you in advance.
Old 07-26-06, 06:31 PM
You did not say what your fountain "should be" so I can't help you with materials. What do you want your fountain to look like? Stone, metal, tile, plastic, wood.... You can make your fountain out of anything you like.
Old 07-27-06, 04:52 AM
whoops sorry about that, well i would like to experiment with a few different materials but for now i would like to make it out of stone or something similar. any suggestions? thanks
Old 07-27-06, 08:25 AM
stone table fountain
I would say hit up a landscaping place, a place that sells stone and stuff. Look through all the landscaping materials they offer nd see what you like ....
Actual construction of your fountain should be easy. The place I go to even has rocks with hole drill in the center so you do not see a pipe or hose sticking out where the water comes out ....
Old 07-30-06, 06:56 PM
i am thinking of adding lights and "smoke" effects to the fountain. what type of lights should i use? any suggestions about where i can buy them? what item produces the "smoke" or "fog" effect? is it a special generator? can it use the water that is being circulated? thank you
