Reline a cast outdoor water fountain.
Old 12-18-13, 03:06 PM
I have a large cast outdoor water fountain and its in need of relining. The cement is coming of in 3x5 patches and joints are in need of filling. What is reccomended to reline? Morter,Cement etc.
Old 12-18-13, 05:51 PM
Got a picture?
Bad time of year to be trying this in your area.
Old 12-19-13, 12:58 PM
Here are a couple of pictures. Also we winter in AZ so the weather isnt a problem.
Old 12-19-13, 10:19 PM
I'd clean it up good with a putty knife and wire brush.
If there any real deep areas with them with Hydraulic cement.
Once it dries coat the whole thing with Dri-Lok.
LATEX BASE DRYLOKŪ MASONRY WATERPROOFER - DRYLOK Masonry Waterproofer
Old 12-20-13, 11:51 AM
Dont you think the base should be recoated with morter or cement? Its really rough inside. What do you suggest i use in the base.
Old 12-21-13, 06:57 AM
New mortar it not going to want to stick to the old.
Old 12-30-13, 05:47 AM
i'd use ' herculiner ' truck bed liner,,, think its only avail in grey now,,, we often coat conc w/it & haven't had any problems [ no $ interest ]. you can locate small quantities on eBay
you need to clean existing conc 1st of course.
Old 01-26-14, 07:19 PM
I'd scrape it clean and paint it with an epoxy paint.
Old 02-12-14, 05:46 AM
why do think ' herculiner ' ? this is our work & epoxies are NOT for exterior use,,, all paints guarantee you more work sooner
Old 02-20-14, 04:23 PM
I certainly agree with the idea of using epoxy paint. There are many epoxies available that are designed for painting the interior of swimming pools so water and sun exposure should not be an issue.
Unless it's leaking I'm not sure really why you want to coat it with anything. Just wire brush off any loose material and leave it like it is. It may be a little rough but you're not swimming in it so you won't notice the roughness. Anything you apply, including epoxy will need to be redone sooner or later.
