Pond dam repair: replace with spillway wall?
Old 08-04-14, 08:23 PM
I have a pond that breached the dam before I owned the property. Apparently, the last dam lasted for quite a while, about 20 to 30 years. It was simply compacted dirt with a culvert stuck through it at about the 4 high. It appears water started leaking around the entryway to the culvert and eventually washed out the dam over a couple of years.
I need to repair the dam so I can collect water in the pond, attract waterfowl, and use it elsewhere by pumping it for irrigation or to fill other small isolated ponds.
The dimensions of the breached area are:
23 feet long channel
12 feet wide at top of channel
5 feet wide at bottom of channel
9-1/2 feet deep
If I put a spillway wall in it would be about 20 feet wide at the front, curved towards the oncoming water pressure. It would be a single wall of CMU w/reinforced concrete poured from top to bottom in the voids. It would also have 3 support ribs of CMU wall supporting it w/reinforced concrete poured from the top down as well.
The rear spillway would be about 10 feet wide, curved away from oncoming water, supported behind it with 3 rows of CMU, w/reinforced concrete poured from the top-down as well.
Please see the rough sketch for my idea. Do you think it would work and last in normal conditions? Actually I tried to load my jpeg image of my sketch but it wouldn't load...said it was too big. Email me and I'll send it to you if interested. Thanks!
Old 08-05-14, 06:41 AM
Shadeladie's Avatar
Super Moderator
Hello and welcome to the forum! Your pic needs to be resized. Try this free program to do it quickly:
Web Resizer - Making Photos Faster - Optimize pictures for websites and email
Old 08-05-14, 09:03 AM
How large is your pond or how much water will you be impounding? You may also want to research if your dam was breached intentionally and if there are any regulations that will apply to your dam.
