Setting up a pump and UV system for pond
Old 06-05-15, 07:53 PM
Talking Setting up a pump and UV system for pond
ok here they are it is a pond light with pond pump attached with tubing
https://www.flickr.com/photos/113163...posted-public/
you can use the side arrows to flip aback and fourth from videos but im kinda lost what to do from here?
Old 06-05-15, 08:02 PM
GregH's Avatar
Super Moderator
Your video shows some pond equipment and what looks like a pond.
What are you asking?
The video is too close in to really show the whole setup.
Describe in deal what you would like to know.
Old 06-05-15, 08:12 PM
i dont have anyone to hold the camera i am not sure what to do with it i have the tetra light green free 9 watts
and pond pump 325 i want to connect theem to put them in my pond to reduce algea and make it clean
Old 06-05-15, 08:15 PM
this is what i did to coonnect them so now i just hang the UVC and then put the pond pump in water?
Old 06-05-15, 09:59 PM
https://www.youtube.com/watch?v=_W7unc01Ss4
it should like this is?
Old 06-05-15, 10:11 PM
It looks like your pump should sit in the water and the UV treatment unit needs to be mounted or placed so that the water runs in to the pond.
Instead of videos.... take a few large pictures of your pond setup from a little ways back so we can see the entire pond and the area around it.
I don't know if they talk about the outdoor electric supply but you need to have your equipment plugged into a ground fault receptacle to prevent any injuries should your equipment short out.
Old 06-05-15, 10:57 PM
i thought only the filter goes into it ? problem is my iphone keeps saying ssorage is full and wont let me
i never seen a filter in water so im kinda confused
Old 06-06-15, 06:00 AM
Pond
Hope these instructions will help:
http://www.drsfostersmith.com/Media/...iperManual.pdf
Old 06-06-15, 07:01 AM
Videos are useless for me. If you could post a description of what you have and equipment you are using would help. So far you've mentioned the UV sterilizer and pump. What filtration do you have? How many gallons is your pond? Will you have fish? If so what type and how many?
Old 06-06-15, 07:57 AM
chandler's Avatar
One of my neighbors holds a US patent on UV lighting clarifiers. They sell them for ponds, household drinking water, and even swimming pools, eliminating the need for chlorine to kill bacteria. It would be interesting to see your set up, as GregH says. Your videos probably clogged up your phone's memory. I may can glean more information from my neighbor once I see what you have.
Old 06-06-15, 10:17 AM
UV sterilizers are cool. You have to use and maintain them properly though so like everything in life you don't get something for nothing. When I've visited ponds that are having trouble and have UV I usually find that they never change the bulb or clean it.
Old 06-06-15, 11:02 AM
I see a Tetra 325 pond pump.
Water Garden Pumps | Tetra Aquarium
I see a Tetra pond "Green Free" UVC 9 watt ultraviolet purifer
UV Clarifiers How To Get Rid Of Pond Algae | Tetra Aquarium
I see a lots of clear plastic tubing.
I also see an inexpensive indoor power strip.
In your hand you are holding a black fitting that screws into the pump. The input side of the pump goes to the filter which sits in the water. The output side of the filter goes to the UV unit.
Tetra has a lot of info on their site.
Old 06-06-15, 04:07 PM
ty the pond stuff is so confusing just been a dream of mine to have one
hey can u see this video? we set it up but look my pond filter gets clogged all the time every day it is under a cherry tree so its not in sun
the uvc blast will fix this?
Old 06-06-15, 04:35 PM
There is no video at that link.
What is clogging the pump ?
You may have to make a larger basket out of hardware cloth that the filter can sit in. It will keep the larger items from clogging the filter.
Just a picture to show you what hardware cloth looks like.
Old 06-06-15, 06:09 PM
sorry this is more clear
https://www.youtube.com/watch?v=FxI1...ature=youtu.be only 300 g
Old 06-06-15, 06:52 PM
it is running the tetra uv is for ponds up to 600 gallons the pump is a bit smaller
Old 06-06-15, 07:01 PM
Is that video your "pond" ?
I can't tell from the video what the filter problem is.
Old 06-06-15, 07:30 PM
that is my pond now set up with the UVC pump and pre filter 3 in one
the pump is only 325 but i already have another powerful BIO pump in th ere
DID you see the other set? it clogs easy i put some mesh in front to see if it stops
