Why does the filter housing leak?
I know this sounds like a no-brainer, but...
I have a Hayward C-250 filter for my water feature. After I clean the filter I clean the gasket and screw down the lid. I turn it on and no leaks. The next morning , I run the pump and the filter housing leaks from the lid.
The gasket was only replaced a few months ago. Why would it not leak one day and then leak the next? Is it a pressure issue? Bad gasket? I’m scratching my head on this one. Thanks.
Look at the area where the O ring sits and where it seals against, both housing and lid, for scratches or gouges that might prevent it from sealing. If you don't find anything I would start by getting another O ring.
The seal looked good to me.
I spoke to Hayward today and they suggested I use a special lube on the o-ring called Magic Lube. I had never heard of that, so I will be ordering some to see if it helps.
For my whole house filters the o-rings have to be coated every time the element is replaced or they will have a tendency to leak.
O-rings work by the internal pressure pushing the o-ring into the voids to seal.
All you need is plumbers silicon grease, which is probably what they are selling but at a higher cost!
I've used petroleum jelly and dielectric grease but I prefer Super Lube Silicone. If you use grease make sure everything is clean as dirt will readily stick to the grease.
You dont want to use any kind of lube that has petroleum products in it, it will break down the o-ring material!
Is there a pressure gauge....so you can compare start-up pressure with a reading later on or next day ?
