Help removing White/Bluish water scale marks on Home Outdoor Fountain Please
See the pics, this is been an ongoing issue - I finally just turned it off n have it sitting there until I can figure how to combat this (Lights on, pump off)
The chemicals seen I got at Home Depot at the recommendation of someone there who said these should work lol. The POOL one, obviously I only add a few drops as I know using too much will cause more scale than removing it. The others I use per the instructions on the bottle (use x amount per gallon or x gallons)
Used these one at a time, would use one, then see in a week if it did anything, if not I would empty the fountain, wash it out with soap, then try something else. ASs a last-ditch effort I tried the algae thing PLUS the clarifier together, but no dice. Then algae plus sludge together, no dice, then algae and pool together, no dice, and this is my final result.
BACKGROUND ON H2O - I live in Vegas, we have hard water. Maybe buying a distilled water machine on amazon and making distilled water from my tap water would help? Hoem depot lady seemed to think with the right treatments they will take care of the hard water issues and prevent this issue, but alas, has not worked. Maybe instead of distilled water just need a filter for my tap like Brita or such to prevent this?
Please help - how can I remove these marks and then prevent them in the future?
YES, I KEEP MY FOUNTAIN ON 24/7 unless my weather station shows a 4+ mph wind speed at my house in which case I have a remote trigger on my phone and I turn off the pump so it does not blow out all the water and burn up the pump.
That is simple calcium buildup where the water has evaporated and left the calcium behind. Nothing in the picture will remove the build up, some vinegar or CLR type cleaner will dissolve the calcium but it's probably going to effect the painted finish.
That color indicates copper or copper sulfate.
Is that statue metal.... possibly a copper mix ?
Is there copper pipe feeding the fountain ?
I get mineral staining in my pool. Mostly iron which is reddish.
I use a chemical called Les Iron (less iron). It is a mineral remover.
By description... it looks almost looks like that Clorox chemical you've got there.
The algae preventers you have been using contain copper. If you keep the water in the fountain chlorinated you don't need to add algacides which will help with the green staining.
You can try acids to remove the deposits you have now. I'd start with lime removers like CLR or Iron Out.
TLDR - ok, it's copper staining.
Eh, initial idea, (have NOT thought through, idea just 'popped in')
Perhaps a zinc sacrificial anode bar would keep the copper from oxidizing?
We just closed on a house in the Phoenix AZ area. It has a beautiful, fairly large water feature in the back yard, just off the patio. It's a rock waterfall, maybe 3 feet tall, 8 feet long. It has a small pond, maybe 50 gallons, maybe more. (can you tell I've never had anything like this before?).
The sellers had a pool construction company muck out the green sludge, and replace the old pump with a new Pentair 1.5 hp Superflo TEFC Pump. The pump, which looks just like most pool pumps I've had over the years, is located on the side of the house, with maybe a 50 foot run between the pump and the waterfall.
There's an old fashioned pool timer for the pump; an Intermatic T101R3 or similar. It was set to run at night, much like I ran the pool system in my previous house.
My question is, should I run the pump every night, for several hours a night? Why or why not?
I'd love to have it running all day too (I'm retired and home a lot during the day), but I'm concerned that's going to kill me on the electric bill. It's much cheaper to run electrical appliances after 8 pm and before 3 pm.
I would appreciate any advice about this, and anything else you can tell me regarding owning a beautiful water feature like this for the first time. Thank you.
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x948/waterfall_pic_f6cfe48488c73c80e99ddb6a9e830ffef1283aeb.jpg[/img]
