Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Ponds, Fountains and Water Gardens
Reload this Page >
Fertilizer injector on siphon valve turned to drip irrigation
Old 04-23-24, 11:14 PM
R
Dear Experts
I am a DIYer and have a basic question regarding fertilizer injectors.
I have two anti-siphon valves at our home, controlled by a B-Hyve Wi-fi smart timer. See attached picture with all labels.
I have converted one of them into a timed controller for use as a drip irrigation system for my 30-35 potted flowers and vegetables. To achieve this, I installed a 25 PSI pressure regulator on the mainline coming in to the anti-siphon valve, to reduce the pressure from 60-70 PSI to approximately 25 PSI for drip irrigation.
I am planning to buy an EZ Flow fertilizer injector (1-gallon EZ 1010HB model). I plan to install it on the vertical 3/4 inch pipe coming out of the anti-si[hone valve (left side on attached picture).
Is this a good/doable idea?
If not, could anyone suggest an alternative arrangement?
Thank you,
Old 04-24-24, 05:50 AM
P
Received 2,236 Upvotes on 1,995 Posts
I personally do not like central fertilization. I suppose it's OK if you are a nursery and have large quantity of identical plants. But if you have a variety of plants of different ages or stages of their growth then one size does not fit all. I would individually fertilize depending on each plant's needs.
PJmax voted this post useful.
