Soft water?
Old 09-13-02, 06:58 PM
Doberman Lady
Soft water?
Ok, heres one from someone who doesnt know anything about pools. (husband talked me into it)
How do you lower the hardness of the water in a pool? I have been fighting this one for a looooong time now. Hardness test is off the scale. I know meratic(?) acid lowers the ph. I needed that. But how do you lower the hardness? It is keeping me from balancing my water. I have well water and need a softener for the house. (as well as a couple of dozen filters) No comments, better than chlorinated filtered toilet water! Short of filling my pool from the softener, how can I soften the water? Should I dump salt in it? It is a 30' round pool. I have had nothing but probs with this pool and ready to BLOW IT UP!
PLEASE HELP!!!!
thank you
Debbie
Old 09-13-02, 07:11 PM
the_tow_guy's Avatar
As I understand it the only way to get the hardness down is to drain some of it off and refill via a water softener. Pouring salt in will do nothing. Pain in the butt, but only way around it. [We're on well also; okay for bathing, washing clothes & dishes, and filling pool, but use bottled for consumption].
Old 09-13-02, 08:01 PM
fewalt's Avatar
Debbie,
What would be the reason to lower the ph in pool water? You'll have less problem with algae, etc. with the harder pool water.
Usually, a softener is used for domestic water use in the house.
Yrs ago my F-I-L bypassed his softener for a pool the same size.
fred
Old 09-14-02, 06:03 PM
Doberman Lady
But that is my problem....ALGAE!!!! I have tried everything to stop it. I was told water hardness was probably my problem.
Old 09-14-02, 10:07 PM
fewalt's Avatar
Debbie,
Ahhh, the real problem - ALGAE.
Algicides and chlorine!
Like I metioned, my experience has shown that algae will bloom easier in neutral or softer water.
fred
Old 09-15-02, 07:55 AM
Here's my algaecide recommendation:
http://www.intheswim.com/catalog.cfm...estTimeout=500
Been using this in my in-ground for a couple of years and have "0" algae problem.
