IG pool ?
Old 05-12-03, 03:00 PM
IG pool ?
how long can i leave my vinyl lined pool empty after i take out old liner , i want to drain it then put in a new liner, just need to have some leeway with time.
Thanks
Randy
Old 05-12-03, 05:16 PM
Ed Imeduc's Avatar
pools
need more info here I think. If the water table dont come up before your done take as long as you like I think. here i have to keep a pump running or the pool will come up out of the ground with no water in it ED
Old 05-12-03, 08:47 PM
re liner ?
hello, my pool is high on the hill and i think the water table won't be a problem. i need to empty alot of water out and want to get in there to get the proper measurements for ordering my new liner. can i also empty the water through the main drain and with the filter on waste with my winter plugs in or should i take them out first?
Thanks Randy
Old 05-13-03, 09:58 AM
Ed Imeduc's Avatar
pool
Not seeing your set up. But from here I would say you have to have all the plugs in for the pump to work right. then turn it on and put the filter on the waste to pump out the water. There is that cheep flat hose that you can put on the waste out let so you can move it around ED
Old 05-13-03, 02:34 PM
re liner ?
that's how i normally do it so i'll do it again like this
