Above ground pool "Ring around collar"
Old 06-03-03, 09:22 AM
rrs814's Avatar
Any "miraculous" methods to remove gray ring aroud water line?
Old 06-04-03, 05:18 AM
BobsRemodeling
Those dirty rings......There are cleaners made for this project at your nearest pool supply store. A soft bristle brush and some elbow grease. Most other products like houshold cleaners cause foaming when used. The cleaners available from most suppliers are highly concentrated to make the job a little easier without harming the liner. Most of this line is caused from heavy swimmer loads using sun tan lotions or water problems. Make sure the water hardness and that there are no metals in your water. Have the water tested at the pool supply store. They will give you a detailed list of what your pool needs as far as chemicals needed to balance your water. This is free when you buy your products there.
Have a nice Day!
Bob,
Bob's Remodeling & Repairs
www.xxxx.com
