Diy Concrete Pool Construction
Old 08-14-03, 02:22 AM
MAVERICK
HELLO,
We are wanting plans and specifications on installing a Concrete Inground Pool and filtration system. Any problems or hints would be appreciated. Thank you.
MAVERICK
Old 08-17-03, 01:47 AM
Here's a howto:
http://areaguides.com/ubuild/swimmingpool.htm
Hope this helps.
Old 08-25-03, 04:07 PM
Ed Imeduc's Avatar
pool
New code here calls for two bottom drains 6 ft apart on same pipe. Also a T off of this pipe under the pool at the drains and come on up with this pipe to open air above ground. This way the drain cant hold anybody on it. also go to
www.llbuildingproducts.com it tell about a pool for DIY ED
