pool drainage
pool drainage
Our pool does not drain away from the house. How much is this a problem? Do the flows into the pool and out of the pool have to be designated and why? Thank you
Received 1 Upvote
1 Post
Keep all your ?????? for one thing in one post not two. It well help. You have to have the pool so no ground water can run into it. In fact code here for the deck is 1/8" per ft down and away from the pool. Yes the in and out lines have to be marked code.ED
