Replacing Jet Tub sitting on ground?
Old 04-14-04, 09:14 AM
raxanne
I am replacing the jet tub in my bathroom. The tub is countersunk from the bathroom floor. When I removed the side panel, I was surprised to see that there was no isulation around the tub and that it was sitting on a dirt floor and not any type of foundation/flooring. (picture attached).
The reason I am replacing the tub is that it started showing cracks on one side. it is a fiberglass\plastic type material. I am concerned that the cracking may have been caused by the tub sitting on the ground.
I want to build a frame to raise the new tub and add insulation.
My question is what to do with the dirt floor. Is there a reason that there was no type of flooring already in place? Should I pour a cement slab to build my new tub frame on or use pressured plywood to create a flooring or just level out the ground and build my frame on the existing surface?
I would appriciate any suggestions.
Thanks
Old 04-18-04, 10:16 AM
Ed Imeduc's Avatar
Most of the time here and like on boats. The hair line cracks are just in the Gel coat is all. Not in the fiberglass.
I have no idea why this was done. let the water out if you have a leak in the pipes??????? I would put a piece of 4 mil poly down on the ground and put in concrete to fill that hole. Do box around the drain pipe say a 10"X10"sq no cement there so you can get at it if need be. Also use pressure treated 2X for any wood that will be on the cement for the tube stand.
ED
