vacuuming above ground pool help
Old 05-09-04, 06:31 PM
sambo099
Angry vacuuming above ground pool help
Bummed out on Vacuuming
Someone please email me a very "detailed" step by step instruction on vacuuming my above ground pool. I've been seeing the word vacuum to waste over and over again i do not have that option but do believe it is drain
here are my valve operattions: rinse , filter, backwash, drain, test , whirlpool, winterizing. I have a Jacuzzi sand filter. This pool was here when we bought house 2 months ago, Nice pool, just don't know how to 'flippin' use it I have all the equipment, vacuum head , hose, handle. Just need an instruction guide cause the manual on the filter is nowhere to be found.
thank you,
Samantha
[email protected]
Old 05-09-04, 09:15 PM
Nixtribe
your vaccume head and hose should hook up into your skimmer somehow, and you would use the filter setting to vaccume your pool. This is how my pool works.
Old 05-10-04, 06:59 AM
Ed Imeduc's Avatar
Wink
Need more info here for sure. what do you want to do.
Most of the time you put the hose in the skimmer intake and vacuum the pool . Or if you have like a pool cleaner a kreepy krauly you can let this on a vacuum out let on the pump intake or in the skimmer
They do just what they say. just be on filter when you vacuum the pool.
ED
