Kid's Pool Maint Question
I live in Southern California. And every summer like a good Californian ( ), I pull my daughters pool out of the garage, and I huff and puff until I get dizzy and pass out.
With all the talk about the West Nile Virus and standing water, I was just wondering if there wasn't more I could do like adding chloring or other chemicals to treat the water. My best guess would say that it hold 75 - 100 gallons of water. This is not the fancy pump kind of pool either. I cover her pool after each use, but I want to do everything I can.
Thanks For Your Input,
seeburt
seeburt
Ed,
My wife brought home the "The Pop Up Pool and Maint Kit" from Walmart", before I had a chance to read your post.
It contains:
1. 1 lb. of Shock 'n Swim
2. 1 lb. of Chlorinated Granules
3. 15 oz. of Stablaizer and Conditioner
4. Test Strips.
The directions make reference to a pump and stuff like that, which of course I don't have, but I guess there's an old canoe orr in the garage that could be used to mix it. My question is...is this what your were referring to?
It contains:
4. Test Strips.
Received 1 Upvote
1 Post
Get the 4 in 1 test kit and use it, Forget the test strips. You will find that with kids""""""" there is no P in our ool You will find that you will need a lot of muractic acid for the Ph. About all you will need is the acid and I like to use liquid chlorine Pool chlorine is 10 % and like clorox is only 5% Just do what the test kit said.
ED
ED
