Install higher wattage heater element?
I have a $1500 Caldera spa from Costco. I don't have the model number handy. It's a 4 person spa with a 4kw/1kw flow through heater element that failed. I was wondering if I install a 5.5kw/1.5kw element if it will affect anything other than the current draw of the hot tub? Namely other wiring in the box. I was wondering if the heater element pulls power directly from the power cord before it enters other parts other than relays.
I am running at 110v and may or may not convert to 220 later.
Thanks,
-JD
Thanks,
-JD
Short answer is no
On 110 volts heater change would put you over 20 amp (1.5/5.5 heater pulls
approx 15 amps and pump running on low speed pull approx 5-9 amp and together puts you over 20 amps gfi will trip however on 220 you could change
with little or no problem. David
'No' is a good answer
The only issue might be the heater relay having a shorter life, but if that was the case, they are spec'ing the parts too closely.
Your numbers aren't adding up; heater elements are usually 230 volts, so the wattage is most likely a 230 spec.
If you aren't getting the heat/ speed of heating you want you probably need to seriously consider the 230 volt option. That should help a lot.
Read (and reread) your manual; that's the best place to determine your options.
At 120volts, what is the recommended circuit ampacity? What gauge is the cord? Does the plug fit a regular outlet, or did you need to install a 20 amp 120 volt receptacle?
