Jets not working
Jets not working
I have a hot tub not sure what make it is bought it with the house. Anyways my wife decided to clean the tub and drained all the water then cleaned the tub and filled it back with water got it heated back up and now the jets don't work . I have checked all the fuses and the pump does kick on but nothing coming out of the jets.
Any sugestion would be great.
Thanks
Thanks
If you are not familiar with the spa I'd certainly go over all the controls and make sure the jets should be running.
If the spa was empty for a while I've seen the water evaporate out of the pumps and the minerals glue the impeller in place so it can not turn. The pump hums but does not pump.
Were the filters re-installed properly? Did anything get into the intake pipes while the filters were removed for cleaning?
If the water heated at least one pump is working to circulate water through the heater. Some spas have a small pump that runs all the time to filter and heat the water and a big one for the jets. Some motors and some control systems have breakers and thermal overload protection. Disconnect power to your spa and open the access cover to see the pumps and controls (the black box not the fancy control panel). Look for buttons (usually red) on the controls and pump. Press each button. Close up the spa and turn the power back on.
Your pump is air locked (filled with air). Find a way to bleed the air out of it and you'll be good to go........ Next time fill the spa through the filter and you should be ok from the start.
The answer... easy fix!
Find the pump that is NOT conected to the heater.
This is the one which has no wires or anything connected to the pipe going into and out of it.
Loosen the uppermost connection and wait for "hissing" sound to stop, and water to begin leaking out, then re-tighten fitting.
Turn pump on and off quickly until water begins to flow freely.
Easy fix.
Any more questions? Email me.
THREAD EDITED:
Forum Monitors Note:
This post has been edited.
E-mail address only removed.
Kindly use the forum topics only, to exchange information.
Email contact addresses are not allowed in the forum topics.
Easy fix.
THREAD EDITED:
Last edited by Sharp Advice; 10-18-04 at 04:21 PM. Reason: Email contact addresses are not allowed in the forum topics.
