turning on spa jets
Old 01-14-05, 05:09 PM
xoxo27bf
turning on spa jets
I haven't used my spa in a long time, and I recently wanted to turn on the jets. There is a small button on the ground between the spa and the pool to turn them on. I saw that the button had been pressed down and it was stuck. I got the button out but it doesnt work now. I have no idea what is wrong. I took the button out and there was a tiny tube I made sure it was connected to the bottom, but that didnt do anything. I was wondering how to fix this, or if there was another way to turn the jets on. Please help.
xoxo27bf@aol.com
Old 01-14-05, 07:28 PM
P
The part you pulled out is an air switch .You can blow into the tube and the jets should turn on. If not, there may be a break in the air line… If the air line is ok and the jets still do not kick on after you blow into air line the relay may be out. Post back and well go from there……
