Wiring Century BN37 1,5hp spa motor
Old 03-05-05, 06:51 AM
NND
Exclamation Wiring Century BN37 1,5hp spa motor
Hello all,
I am almost finished with all the connections related to wiring my Spa.
The Century pump I have really came with no directions. A simple schematic that makes no sense to me.
The pump is 115V and I have four wires coming from the control unit. Red, Black, White and Green. The green is a no brainer and it's on the ground plug.
Looking at the back of the pump there are three connections remaining. #2, which it say's is "Line". #3, which it say's is "High". And #4, which it say's is "Low.
After much googling, I can't find a wiring diagram at all for the back of this pump, and after all the time I have spent getting everything together, I don't want to burn anything up. :-)
I have read the black wire is for the "High" speed connection #3.
I have read the Red wire is for the "Slow" connection #4.
The only thing left is the "Line"connection. Is this for the white wire?
If anyone else has wired a 2 speed motor let me know this correct, beofore I fire it up.
Thanks in advance.
NND
Old 03-05-05, 05:38 PM
white would be your common wire, or # 2 in your diagram , ............... # 3 = high speed ........ # 4 = low speed
steve
Old 03-06-05, 06:06 AM
NND
Wiring Ordeal
Thanks Stevie3x
I'll crank it up this afternoon, and let everyone know how it goes.
Thanks again.
Old 03-12-05, 06:35 PM
NND
Works
Everything works fine.
Thanks a million!
