Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
What's best device for blowing lines in winter?
Old 03-12-05, 06:04 AM
Javit Ersoy
Hi all.
I've been told a standard air compressor blows "through" the water, not displacing it well. I'm considering buying a high volume blower (kind pool companies use). Any suggestions?
Old 03-14-05, 02:18 PM
you do need voluume, not necessarily pressure, I use co2
steve
Old 03-15-05, 06:21 AM
If you are just trying to winterize, then a compressor is fine. All you are trying to do is gen enough water out so the lines don't compltely freeze and bust them. If you use air, then add RV antifreeze you should be fien. I have also use a shop vac to suck out the water and find that this works better than pushing the water through with air.
tom
Old 03-15-05, 07:12 AM
Ed Imeduc's Avatar
Wink
Im with 66ponyboy use a shop vac Kinda late for this this year now
ED
