Insulation
Old 03-17-05, 05:22 PM
Insulation
Hi, does anyone know an easy method to remove the insulation and replace it in a hot tub? Thanks, John
Old 03-17-05, 07:21 PM
Hi John, if your refering to the polyeurthane [ spelling ? ] apx 1 " thick almost allways yellow in color , we use a razor knife to cut where were going to put a jet or replace a jet and scrape it off with a putty knife, is this what you had in mind ?
steve
Old 03-18-05, 11:18 AM
Ed Imeduc's Avatar
Wink
Can you just cut it out and use the "GoodStuff" Foam in a can. To fill it back in.
ED
Old 03-18-05, 01:55 PM
insulation
Hi Steve, Yes , I have a leak and i am going to try sealer first, If that don't work i'll remove some insulation like you said. Haven't looked at bottom yet. Thanks alot, John
