Inaccurate hottub temperature reading
Old 03-30-05, 07:27 AM
I have a 1997/98 model Beachcomber 730 hottub that is giving me a temperature reading 2 - 3 degrees lower than the actual temperature of the water when I measure it with a thermometer. The display light on the digital display panel is out as well. Are these things easy to fix or should I call a technician?
Old 03-30-05, 09:34 AM
Pendragon's Avatar
Try another thermometer, or several. You'll find no two thermometers are going to give you the exact same reading unless they are calibrated.
I wouldn't worry about, set the water to a temp you like, just use the thermometer as rough point.
You could probably replace the light yourself, but you'd need a parts break down to even see if it's replaceable as a single piece or not.
Old 03-30-05, 06:53 PM
try this, heat the spa up , apx 102 then check the temperature using a human themometer , you know the type, your mama used to place under your tongue, youll will get an accurate reading.
steve
