Pool cover question
Pool cover question
Is there a such thing as hard pool cover - something that you can safely walk on? I've heard of someone having it but I can't find any references to it. Thanks.
there are many companys that make different types of covers, from reinforced fibers, [ a child can walk on ] to open weave type that will also support a childs weight, there used to be a company called lift-o-matic , a hydraulic activated cover solid, translucent panels that when partially raised formed a wind block and when completely raised was a cabanna type cover,
not cheap, suggest you go to your local pool store as they should have information on all the different types in your area, do to the fact that whatever you decide on will have to be installed , I would deal with a local concern for better service in the future.
steve
steve
