Height of pump
Old 05-24-05, 10:42 PM
khooper
Height of pump
I'm currently in the process of installing a 18' above-ground pool.
One side had to be dug out 22"
If I place the pump where I want to, then it will sit on the ground about 2' higher than the pool bottom. Will this cause a problem? It's a 1 1/2hp pump and sand filter.
Thanks everyone!
Karen
Old 05-25-05, 10:12 PM
Hi Karen, seeing how most 18 ft. above ground pools are 4 ft. deep at least, your pump and filter will be below the water level, no problem other than add 2 valves one before the pump and one between the filter and pool to shut off water flow during the time you need to service the pump or filter,
recommend hayward 2 way valves apx $40.00 each, well worth it.
lol steve
Old 05-25-05, 10:41 PM
khooper
Thanks so much! We will definately plan on adding valves both before and after the pump.
Karen
Old 05-26-05, 07:49 AM
Hi again, remember to add the valves ..... BEFORE the pump .... and AFTER the filter ,
lol steve
