Hayward Vari-Flo XL Malfunction
Old 06-11-05, 10:53 AM
JACQUESR
I have an old inground pool with a relatively new Hayward Vari-Flo XL filter. It seems to be discharging pool water from the backflow/waste line at the same time that it's filtering. The spider gasket appears to be in good shape. Can someone tell me where or what to check out if this gasket is not the problem?
Thank you
Old 06-11-05, 03:01 PM
either the gasket or the body of the valve has a crack in it, if theres no de returning to the pool during filtration put a shut off valve on the backwash line and that will solve your problem , for awhile , however what ever the problem it will not just go away.
steve
