Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Pools, Spas and Hot Tubs
Reload this Page >
Problem with DE Filter holding suction for vacuum
Old 06-11-05, 03:31 PM
rgroski
Question Problem with DE Filter holding suction for vacuum
Help!
I just opened my above ground 28' round Doughboy. The filter is working well but my problem is starting the vacuuming.
I put the vaccum hose in the hole leading to the skimmer, with the filter off, I place the skimmer top in the skimmer on top of the trap basket and turn the filter on.
There is suction for 5 seconds and then the second trap basket drains of water, then bubbles up with water and the suction dissappears. I turn off the filter at this time and the top pops up with a lot of air.
Any ideas of what is wrong. I never had this problem before and I have had the pool for 20 years.
Thanks,
Rich
Old 06-17-05, 11:03 PM
Dpdblues
Make sure that before you hook up the hose to the skimmer that you fill it with water from the return jet. Once that is done then place the hose on the skimmer, that way there is no air gapped into the pump
