above ground pool location
Old 06-14-05, 10:20 AM
We've decided to get a 20' above-ground pool- In order to install the pool in our yard- I need to remove 2 pine trees (one is about 40' tall- the other is about 20')- Once I remove the trees and have the stumps grinded down- Is it a good idea to have the pool installed in that area?? Will the roots decompose and cause the pool to sink eventually??
What are my options?
Old 06-14-05, 03:50 PM
poolspapro's Avatar
Tree Roots
Ski Nut,
My first job (too many to mention) was working after school and out with an Arborist. Few root systems even after several years have had a problem with the yard sinking from root decay ( I re-visited a few of the same yards when I was foreman for a sod company). If the proper prep work is done at the base for the liner than you should be fine for the life of a few liners. I think you would be better served though if you were to post this same topic on the Garden/ Landscaping forum. Since someone there is more "in the know"
