above ground pool location
Old 06-15-05, 05:16 AM
We've decided to get a 20' above-ground pool- In order to install the pool in our yard- I need to remove 2 pine trees (one is about 40' tall- the other is about 20')- Once I remove the trees and have the stumps grinded down- Is it a good idea to have the pool installed in that area?? Will the roots decompose and cause the pool to sink eventually??
What are my options?
Old 06-17-05, 12:29 PM
As long as you make sure they grind away the stumps completely you should be ok. Decomposing roots shouldn't pose to much of a risk. Just try to stay away from the stumps as much as possible. Some tree companies only grind the stumps down a few inches below the ground. If the stumps aren't completed gone and start to decay that can cause a problem
