wiring Hayward pool pump -- neutral wire
Old 07-01-05, 06:43 PM
mike-n-bon
Hello -
I am sure this question has been asked before -- where does the neutral go on a pump? Is it supposed to be connected to the ground?
Old 07-03-05, 05:26 PM
P
Check the wire diagram on the side of the pump and in the owner’s manual.
Old 07-04-05, 09:28 AM
bjdelephant
I just purchased a hayward h series, how do I wire? the diagram shows 2 wires coming from field but does not distinguish nutural form hot
Old 07-05-05, 05:19 AM
mike-n-bon
I have finally found an answer -- and not on this forum. If the pump is wired or set for 120vac, L1 is hot, L2 is neutral. If your pump is set for 240vac, then I undestand that L1 and L2 are both hot. I don't know where the neutral goes, if at all, on a 240vac pump.
Old 07-09-05, 07:45 PM
most motors 1/2 hp thru. 1.0 hp can run on 120 vac or 220 vac , on a dual voltage motor they come ready to run on 220 vac , if you intend to run it on 220 vac [ which draws less elec. ] no neutral is used , one load is connected to line 1 and the other load is connected to line 2 , however if you want to run it on 120 vac you will have to switch wiring at the rear of the motor , the diagram for doing this is on the sticker affixed to the side of the motor.
steve
