What type of gas line for a pool heater
Old 07-06-05, 04:04 PM
thundar
Smile What type of gas line for a pool heater
I have an above ground pool.I'm installing a new heater.I need to run a natural gas line to the pool and line will be buried.Can I use copper line say 1/2" or does it need to be the plastic type line.
Old 07-07-05, 08:15 AM
P
Check your local codes, plastic has to be run deeper and you need to run a tracer wire with it. Or you can use Galvanized X-coat and prime and tape all the exposed metal (fittings).
Check your distance so that you put in the proper sized gas line.
