DE Filter Question
Old 07-09-05, 06:36 PM
jayedmo's Avatar
DE Filter Question
I am having a serious problem with my water clarity and I tried everything and nothing seemed to work. I had a sand filter and I found that it was sending all the dirt and junk that I vacuumed up back into the pool. So I replaced the sand and the same thing happened.
To make a long story short, I just bought a DE filter. How much earth should I put into the skimmer. The guy at the pool place said 4 coffee cups, but I read somewhere that 2 1/2 cups will suffice...which one do I go with? How long should I run it? My water is still cloudy...the pH is b/w 7.2 and 7.6 and free chlorine is around 2 ppm..
Old 07-09-05, 07:35 PM
what size is the filter ?
what horsepower is the pump ?
how many gallons in pool ? [ don't guess ]
steve
Old 07-09-05, 08:02 PM
jayedmo's Avatar
Pool size is 10,500 gallons--21' round
1.5 HP motor
DE Filter is Lomart Ultima 5000
Old 07-10-05, 03:06 PM
not sure by your post the size of filter , however most 1.5 hp pumps can 50 to 60 gallons per minute , you have a d.e. filter which is super, keep your chlorine 3.0 for now , ph 7.4 - 7.6 and run the filter 24 / 7 until the pool clears, when the filter is clean you will have to add d.e. to the skimmer while it is running, again im not sure of the size , 36 sq. ft. 48 sq. ft.
60 sq. ? ? so i can't advise the proper amount , [ ill try to find there web site ]
at any rate note the psi reading when the filter is clean and has the proper amount of d.e. then when this psi reading increases by 6 psi , its time to clean the filter again , regardless of how long since you last cleaned it.
when you get your water clear , you will need to run your filter a minimum of
3 hourss daily i would up this to 4 hours for good measure.
60 gpm X 60 min. = 3,600 gal per hour. 3 hr. = 10,800 gal
also take a water sample to your pool store and ask them to check it for conditioner level.
steve
Old 07-10-05, 03:30 PM
jayedmo's Avatar
Went to the pool store and they told me that my chlorine is low and that most of the cloudiness is due to dead algae. They told me to try a flocculant and to raise my chlorine level...
Old 07-10-05, 05:41 PM
do to the fact you have a d.e. filter , you do not need a flocculant, if you have the correct amount of d.e. in your filter and chlorine in the 3.0 range and run the filter 24/7 it. will clear up guaranteed.
however you may need conditioner, have the pool store check that for you as your test kit more than likely will not test for conditioner .
steve
Old 07-11-05, 05:43 AM
the_tow_guy's Avatar
The literature on your filter should tell you how much de to use, but 2 1/2-4 cups doesn't sound like enough. Mine takes two coffee cans of powder (it tells you how much to use in "pounds" and the two coffee cans worth is a close approximation of the correct amount for me).
