How to drain this thing , need your help
Old 07-10-05, 04:57 AM
im_nightrider20
Unhappy How to drain this thing , need your help
Hi everyone,
We are new home owners and we have a hot tub on our deck. I wanted to drain it and clean. I cant find the drain openning so I can attach the tube. Its a "barefoot spa" hot tub. Please help in finding the drain opening.
Thanks
Nightrider
Old 07-22-05, 12:07 PM
Did you look in the service panel?
Don't know about your tub, but mine has a hose inside the service cover ( where the motor, heater and wires are) you pull the hose out and remove the cap.
Good luck
Old 08-10-05, 01:17 PM
adventurer
draining tub
I couldn't get my drain to work on our hot tub so I used a sump pump with a hose on. I just put the pump in the water, attached a hose, and watered my garden with the water as I drained the tub. I use bromine as a sanitizer and the levels were low when I drained the tub so it didn't hurt the plants at all!
