what to do next?
Old 07-11-05, 10:03 AM
garif0
what to do next?
I just refilled my pool with water...
What do I do next to treat the water and make sure it is balanced correctly?
Thanks in advance,
Garifo.
Old 07-12-05, 06:06 PM
1. you need to add conditioner to obtain 50 ppm [ parts per million ]
2. adjust chlorine level to 2.0 - 3.0
3. add enough muratic acid to put your ph between 7.4 - 7.6
youll note i did not tell you how much of what to add , as ALL chemical additions are dependent upon total gallonage of your pool.
for square or rectangle multiply length x width x ave. depth x 7.5
for round multiply diameter across say its 18 ft. you would multiply 18 x 18 x ave. depth x 5.9 , if its a free form , walk around the perimeter with a walking rule , say its 90 perimeter ft. multiply 90 x 90 x ave depth x 4.165
steve
Old 07-13-05, 09:05 AM
garif0
thank you for you reply.
I tested my water
Ph is 7.4...chlorine is 1.0 so I will be adding chlorine.
great help
Old 07-13-05, 09:21 AM
Ed Imeduc's Avatar
Wink
You only need the chlorine between 1.0 and 1.5 You didnt say anything about the alkalinity. dont forget that.
ED
