urgent - skimmer placement?
Old 07-12-05, 07:49 PM
alandail
our pool we are setting up (20x40 - 9 foot deep end) has two skimmers. I have always heard that the skimmers need to go on the east side, so I was going to put one in the shallow end, one in the deep end, both on the east side, which is how I saw someone else do it.
However, the tape from the pool company said to put one on each side. Which is the preferred way to do this?
Old 07-13-05, 07:19 AM
It depends on the placement of the return lines as well; I would put them in on opposite ends in most cases.
Old 07-13-05, 08:30 AM
alandail
I was going to put the return lines on the west side, opposite from the skimmers. So, something like this?
r|.......|s
r|.......|s
..N
W.E
..S
Is that what I should do, or should I do something differently? We're hoping to set these later today. The walls came with the skimmer holes cut out already.
Or am I better off with either of these (the deep end is the north end)
s|.......|r
r|.......|s
r|.......|s
s|.......|r
r|.......|r
s|.......|s
s|.......|s
r|.......|r
Thanks
Old 07-13-05, 04:48 PM
alandail
nevermind - I found out the skimmer is an aqua genie and it is both the skimmer and the return. I also found out that it doesn't matter which side it's on - but they both need to be on the same side and that I don't need a center drain with this skimmer. Also, I don't have to drain the pool in the winter, just put a special cover over the skimmer.
